wasted wages
1 ton status
one can only dream to aspire to this level of fabrication......
http://128.83.80.193/scarysteering/scarysteering.html
http://www.mime.eng.utoledo.edu/people/faculty/afatemi/papers/2004SAEZoroufiFatemi2004-01-0628.pdf
Page 10- has some interesting conclusions, although the materials are technically not the same as discussed here.
Don't get me wrong, Blazr77400 does some nifty stuff with a CNC mill <snipped>
Freudian slip ??????It's also impotent to understand that using 7075 over 6061 would have little impact on the fatigue life of the part. Though 7075 is stronger, it has about the same endurance limit as 6061. Additionally, many engineers will argue that aluminum has no "real" endurance limit.
Pronunciation: \ˈim-pə-tənt\ Function:adjective Etymology:Middle English, from Anglo-French & Latin; Anglo-French, from Latin impotent-, impotens, from in- + potent-, potens potentDate:14th century 1 a: not potent : lacking in power, strength, or vigor : helpless b: unable to engage in sexual intercourse because of inability to have and maintain an erection ;Aluminum does not have an endurance limit,
Wrong. I just looked it up - the endurance limit for 6061T6 is 14ksi. That is presumably measured using a standard R.R. Moore 10 million cycle test, so while it may not be a 'true' infinite endurance, 10 million cycles is a LOT.
That is actually how the endurance limit is defined for all of the materials, 10 million cycles is the line for when something will have an "infinite life". If its loaded below the EL (14ksi apparently for 60601T6) then its considered to have an infinite life and not fail in fatigue.
Most aluminums don't have an endurance limit, apparently 6061T6 does.
For comparison, 1020 steel (what most of the steel arms are probably made of) has an endurance limit at 22 ksi or so.
Here is a chart showing steel vs. aluminum (5xxx grade), this is how the two normally behave (but NOT in this case). As long as the loading is below a certain limit (3xx MPa or 20ksi for steel) it will last forever. Aluminum usually has no endurance limit.
I went and measured my steering arm to make some quick hand calculations, my arm was 4.5" from the draglink hole to the front of the knuckle mount surface, 3.5" wide and 1.25" tall.
stress = (6*1000lbs*4.5in)/[(1.25in*(3.5in)^2] = 1763 psi = 1.763 ksi
1000 lbs. of steering force is probably pretty generous.
That puts the regular steering force well under the endurance limit and WAY under the 35 ksi that the material would yield at.
So there ya go, IMO, this steering arm looks perfectly fine in my eyes.
Its pretty easy to surmise that the arm won't inherently fail, and now that we know that 6061T6 has an endurance limit, I'm not the least bit surprised it all looks good.
I'm pretty surprised that I didn't know that 6061T6 had an endurance limit unlike most aluminum, its a really common aluminum alloy.
That's a pretty surprising post at the end of this thread, I think![]()
Durability should be a part of this discussion. The OEMs design this stuff to be cheap to build, and usually easy to service. Tapered joints in aluminum do not fit that description.
I'm not dissing the craftwork, but it seems out of place for hard working trucks.
the only thing im concerned about is the use of the zip ties to retain the brake line to the shock body,
the deflection front the bushing and frame flex could over time cause slight movement and stress the plastic/nylon, thus failing and the brake line could float in the breeze..just like the factory allowed.
scary thought, just keep an eye on those zip ties![]()
