Bilstein shocks
cybrfire
1 ton status
Iowa
We're getting some good deals on Bilstein shocks right now. Like to pass them on to you guys.
Let me know what you need, part no. works best, and I'd be happy to get a quote for you.
price on 4 14" travel 5150's shipped to 85532 please
Just making sure but 14" travel bil's will fit on the rear of a 4" shackle flipped Suburban correctly yes? Otherwise 2 and 2 of other size. Thanks
Josh
Josh
I always recommend measuring for you particular setup but if I had to advise without taking them measurements, 14" travel is gona be to long to mount the way you need to in the factory mounting locations.
I'll get some quotes for the 12's and 14's and so on and post them up here.
Sounds good. The front has extended mounts I'm putting in so 14" should work for that however the rear is the one I'm concerned about.
255/70 valving 12" travel P/N 25-101874 $115.80
170/60 valving 12" travel P/N 25-186277 $102.88
255/70 valving 14" travel P/N 25-101980 $115.80
255/70 valving 14" travel P/N 25-187588 $102.88
Thanks for the opportunity to quote and let me know!
Are you still able to source Bilsteins at a reduced price? If so let me know, I'm looking for a set of four (front and rear, I do not have the dual shock setup in front) for my factory '89 Jimmy (fullsize). Nothing fancy, just normal OEM replacements.
Thanks!
edit: found the part numbers I need:
2 of these:
Rear:
Part Number: 24-009331
Old Part Number: F4-B46-0933-H0
Old Part Number: F4-B46-0933-H1
and 2 of these:
Front:
Part Number: 24-009232
Old Part Number: F4-B46-0923-H0
Old Part Number: F4-B46-0923-H1
Price on 2 7100s and 2 5150. 12" travel or so
Oops didnt realiz it was old lol
