Georgia.mule
Registered Member
Hey all, Looking for just a lil help, I got another Blazer, I picked up an 86 that had hit a deer in the nose, they put a 90 1500 pick up nose on it, its not too bad, however i am finding rain water leaking into it, 1st spot was right over the drivers side windshield, two rivlets would run down the inside while driving in moderate rain. 2nd spot is the drivers side kick panel, or actually just above it, the water comes in and drips down on panel, and the emerg. brake release and thye hood release, 3rd spot. pass side kick panel, leaks onto the panel and the floor from the bottom outbord edge of dash and from the vent actuator cover. Any body seen this before or have any idea's. got black window rtv from the zone and sealed all around the inside edge of windshield gasket (against the glass) and it seems to end the leaqk from above the drivers side, but not the others, did a seal around outer edge of windshield gasket (against body) but still have leaks 2 and 3, if you've seen this or have info please email it to me. Thanks.
