Blazer Bash 2011 BBQ Swap Meet
PANCAKE
Arvada, Colorado
I am going to BB 2011 and have some parts I need to get rid of.
Is there a swap meet planed?
What I have:
Dana 44 raised steering arm
tbi air cleaner assembly with a K&N filter
32 gallon fuel cell
HEI Distributor
NP 205 syncromesh front out put shaft with shift rail and fork
1350 yoke for a 205
1350 yoke for a dana 60
Tow strap (2)
Tree saver
Edelbrock Carb w/ off road needle and seat set (2)
th400 stock (1983) torque converter
Rear sliding window for a 73 to 80? truck
dual Rancho Steering Stablizer shocks (almost new)
I know there is more but i can't remember it all :rolleyes:
Looks like you almost have enough to put together a backup trail rig... :haha:
maybe just use the bbq as the swap meet too. It seems hard to catch up sometimes with other people, but all the cool kids will make the bbq!
Yeah BBQ will be the best chance. Maybe Friday at Area BFE, but that's new this year so I don't know how that will go.
maybe change the title of this thread to swap meet at the bbq, just so people can see it.
Also have a new Dana 44 tierod with both ends and sleeve from Moog (NEW).
and a Centereforce Dual friction clutch and flywheel gently used.
The flywheel fits a fuel injected Chevy 350 (IIRC the fuel injected flywheel is diffrent from a non-fuel injected block)
I am building a 89 k5 so I am parting out my 78, most of it is still up for grabs along with a bunch of other stuff I have gathered, 383 stroker TBI, roll cage from jegs-bolt in, D44 4.56 ARB, 14b 4.56 Detroit, figure 8 205 and the adapter for t400, 6" lift, 203 tcase, 35 12.50 16 BFG at's 95% tread, and all the other parts on it. I also have a 700r4, 241 tcase, that came out of the 89 and a pile of drive lines. If you need a part off a blazer let me know I probably have it.
435-820-1068
I have 4 36x16x13.50 irok radials, withOUT wheels, along with 1 brand new 36" tsl radial mounted on a black steelie 8 lug. Iroks are around 65%, one plug froma few years ago, all hold air fine though. Already sold! I locally
I have a raised steering arm and a dropped draglink for a 10 bolt of 44.
I have a 38x12.5x16.5 swamper on an 8 lug wheel, its brand new but several years old, bought it to use as a spare I never carry it anywhere with me, on a black rockrawler rim I will get pics up
Anyone have any h1 wheels to sell, factory or rockwell recenter.
Also looking for some 20"double beadlock wheels for rockwell too.
I have the following:
GM 12-bolt rear axle (6-stud), complete with brakes and lines, open diff, 3.07 gears.
One pair - Yukon alloy 12-bolt axle shafts (6-stud) with 1/2" wheel studs, never installed, carried as spares.
Driver and passenger highback seats and brackets from a 1984 K5 Blazer, vinyl is poor to fair - seams on seat bottoms torn, foam is still good. With included neoprene seat covers, they look (and feel) in good condition. These were in use until recently when I installed some suspension seats.
Looking for 1 37X12.50X17" Tire BFG Perfered No actually thats what IM looking for LOL unless someone has a Full set of something else... Bigger
We might have a full set of axle shafts/u-joints out of a 90 1/2 ton suburban 10 bolt front. Building a race truck and gutting the front axle.
I have a set of Hutchinson aluminum double beadlocks. 16" wheel, rubber beadlock center. They were made for GM for some custom boarder patrol trucks from what I understand.
These aren't mine, but this is what they look like. If I remember correctly they are a 8 or 9" rim with 4" backspacing.
attachment.php
I've got a dropped draglink (ORD?) for a Dana 60 with Crossover. New heim joints on both ends. $100
And four 38.5's Swamper radials on 10x16.5 aluminum wheels. I don't have them with me this second, forget what kind of wheel, tires are good at 50% or more. $400
I also have three 12 x 16.5 Weld Typhoons in good shape. I have the fourth, if you know how to bend aluminum you could maybe fix it. The tire went flat, drove on it, flattened the bead. $100
I would only bring these if I knew for sure someone wanted them.
