Blazer Bash 2020 last minute thrash
Ordered stuff to switch up my front shock mounting location and looking into a weld on steering box frame brace so I dont end up like @ashman. So much to do so little time ;)
Fingers crossed I get my sye and 241 in before next year*
New jd2 bender already ordered, talked to Jessie at ORD front 4 link on way, rear double triangulated 4 link sitting in garage, ordering an expansion tank for fuel injection later this week.
:grind::hack::weld:
I'm on it!
:popcorn:
:grind::hack::weld:
I'm on it!
Is Marty still going to be Marty?
Replace sector shaft bearing
Build retainer for lower sector shaft
Replace tie rod ends
Remove passenger side front spring, pull inner spring shins and replace bushings
Cut front cross member and brace to eliminate interference
Replace axle shafts and ball joints
Sounds like that's half way to a dana 60 swap:dunno:
Last year was the first time sense 2013 I missed, I had a good run.
Bring your truck in 2020!! That needs to be your slogan. Trailer it, drive it, ship it, etc. just get it there for us to see and YOU to use it!
You built it right. Don’t second guess, just do! :waytogo:
It seems about every other year the truck comes with me. I just don't feel comfortable driving it that far, not saying it can't do it I just don't want to.
Well even though I have a great tow truck my goal is to have a driver, that can go anywhere.
The only reason I would consider towing is if I want to travel in my big rig as an rv and have my suburban for local trail rides where we stop.
But I prefer overland trips the most.
