Blazer Bash 2023 last minute thrash.
I have the whole front axle apart.
No front drive shaft.
Will service trans for 3rd time in less 20k miles, go back to stock pan, for drive shaft clearance.
Valve cover gaskets and front crank seal minimum. I want to pull the motor, and spend some $$ with @folkenheath and get some new heads, retro fit roller cam, but at my current pace looks like just fix the oil leak and live with the compression.
Nut, bolt fluid check. Maybe stick in a cb, it had one at one time coax and power still there.
got some tie down tracts for rear cargo area need to install.
figure out what I want to bring for spares then cut that a third or more.
@500$k5 did you build the tank skid or is that the CFMi skid? If CFMi, please post feedback for quality and fit. Thanks!
Currently debating if I take my truck or not. Either way it needs a prep from last years shenanigans.
This event happens every year. You would think that would motivate people to fix their junk right after last year.
If only a Blazer was the only thing that needs work....... Dirt bike, street bike, atv, SxS, daily driver, camping truck, camper, Blazer, drag car........ I have a headache.....
Been working on other projects and was wanting to give it a rest this year to motivate someone else to get their K5 done.
Front axle is done, front drive shaft installed. Back to original trans pan, deep one won't clear the drive shaft. Topped off the a/c.
Not going to be updating the engine, just fix oil leaks.
Still need to add my arb compressor, put in cargo tie downs. modify the spare tie down. replace bent drag link. All in all I could leave tomorrow if I had to.
Same, it’s just how much I want to be prepared and not anal and over think things.
