Blazer Bash 2024 GARAGE SALE!!!!
Raggedy_Ann
Denver Colorado
Let's get this sale going! Post up what you got with a price. As I find things I will post them up. I know some of you guys are hoarding the good stuff, dust it off and sell it!
DIY4X tie rod clamp, 3in long and takes 1.5 dom
$45
67-72 Front frame brackets for tow hook/ recovery point
$80
4 super swamper Irok 42x14R17 on h2 wheels, wheels have rock rash 21 32nds tread left. New has 24 32nds. No patchses all hold air. One tire one lug has a chunk missing from it. Can bring to Blazer Bash
$2000
I'm selling my tires and I was offered an awesome trade but I don't need the offered wheels. Wanted to extend this offer to ck5 if anyone wants these. Hutchinson double bead lock 17x9 8 lug on 6.5 with 5in back spacing total 5 wheels with beadlock inserts. Looking to get $1700
- Warn non premium 30 spline locking hubs for GM/Dodge D60. Used, worked flawlessly when removed but upgraded to 35 spline. SOLD
- Pro Comp 17x9 8x6.5 Steel wheels. Scratched, dented in some spots. Set of 4. SOLD
- 2002 LS 6.0, 175k miles, ran when pulled, complete with extra alternator/PS bracket to replace the broken one. $900 OBO
- 1991 4l80e out of V2500 suburban. Is a core only. I burned this one up behind the LS swap. Swapped to a newer 2001 rebuilt. $300 OBO
- 2005 4l80e out of 2500hd. Bought this for my K5 but going nv4500 instead. Is a core only, clutches are toast, needs rebuilt. $350 OBO
- I also have a total of 4 np203s that I am not going to use. Some were pulled from running/driving vehicles. If anyone is interested I will verify condition for you. Can pull just the range box if that's what you want to. $100/piece?
I will be in Moab for Blazer Bash 2024. Probably pulling in evening of Sep 5th. Shoot me a PM if you want anything listed here. I can get more pics if necessary.
It's gonna be hot on Moab, I know someone is gonna be wishing the had a bigger transmission cooler....
- Dorman 610-301 9/16 wheel studs, set of 18. Brand new. $30 for all
- Factory Squarebody under splash shields. Bought new a few years ago for my K5 but had to remove for cage tie in. Includes hardware, no cracks. $30
- GM/Dodge 30 spline D60 stub shaft. Used, upgraded to 35 spline. Perfect condition. $50
- Factory 1991 Squarebody power steering "cooler". Removed from my V2500 suburban. $30
- Factory 15x8 rally wheel, 6x5.5. $50
- D60 OEM cover. Used but never saw rocks. $40
- Squarebody 81-up 4wd steering gear. Unknown reman from rockauto. Bought in 2017 or so and removed in late 2018 for crossover. $100
- 4l80e 4wd adapter, used. $50
- Steel winch cable. Came off harbour freight 12k. Make offer
- Squarebody flat crossmember. Came off 84 with sm465. Make offer
I have a set of 4 super swamper tsl radials 36x14.5x16 with a set of beadlocks for sale there is maybe 2,000 miles on the tires so they are still pretty much brand new. They have been to Moab a couple times and just getting broken in. The bead locks are steel and not mounted to the wheels but I can do that if u like. You also can run these rims in a non beadlock and just as a street legal rim. Looking for $2000 out of them. Will be willing to bring them to blazer bash this year. They are 8 lug rims.
IMG_3999.jpegUnused 3/8” steel winch cable off of a 12K Milemarker winch. I think it’s 95 feet if I remember correctly. $20? Picked up at Blazer Bash
Gm remote key less entry, worked in my blazer when pulled. $20
Gm 6.5 diesel fuel filter $10
Gm 6.5 diesel glow plug relay $10
Holly red fuel pump $20
Autometer trans temp gauge with sensor $30
Stainless steel braided brake lines 2 at 32in other 2 at 29in $20 for all
Stock gaugses and dash parts make offer
Metal interior trim give me 1 raffle ticket
Will bring to Blazer bash
I'll take the holley fuel pump and the trans temp gauge.
I’m interested in the remote keyless entry, it I won’t be going to blazer bash this year.
