Ok, my Blazer has vinyl buckets, they are like brand new, but vinyl seats get hot, very hot, and also get sticky when it rains, (?) so I decided I would look for some cloth seats, I friend of mine has an 86 454 C20 Suburban, We pulled the front seat out of back in July to mount on a tool box, and sit on at the truck pulls and mud drags. We did that and learned that it is very, very comfy.
Call me weird by I've always preferred a bench to buckets, so I asked If I could get that seat, and I got it.
Today I pulled the seats out, broke one bolt, and discovered a bit of floor rot, (not much, Its only about an inch around that one bolt, so don't get too worried) and when I had the seats and seat frames out, I set the bench in, and learned that the hold are all about 3-4 inches off, and it sits very low, like mexican syle, so then I decided to put the frames back in on the wrong sides, and then it turns the holes on the seat are still about 3 inches away from the ones on the frames too.
So now I go back to the garage and make some brackets to make the front bolts line up, enough so that its alteast "mounted", I hop in, and instantly learn that something anit right, the steering wheel is all the way up, and and its in my crotch, and there is about 4 inches between my head and the roof.
I didn't think that the seat from a Suburban would be that different from a Blazer's. Did the Suburbans have special seat bracket? Or do I need the one from a pickup? I know the floor in a pickup would be different from the saddle tanks.
