Blazer build Ya that's right
timamybrown
Registered Member
coon rapids Mn
Doing some work to the K5 just thought i would share some pics. Installed 2x6 1/4 wall rock slides and few new bars in the cage and i'm in the starting on the front.
It's 2x6. I cut the floor out so bottom of the 2x6 would be the same as the floor to get a little more ground clearance
looking good....
how'd you post pics with 3 post'eses...?
He'd paid up and attached the pic's...
Nice cage work!
Rene
most excellent work, welcome to CK5.
The rocker box is gone the slider tie's into frame i used 2x2 1/4 wall from frame to slider, and welded the slider in just like a factory rocker.The cage is tied into the slider and frame.
I like it just one questions you have it torn down so much why not go through the dash with the cage. Or did you have the cage before you started hacking away.
The cage was already in and there really was no good way to tie into it. And everyone goes threw dash just wanted to be a little diffrent
