bigbadchev84
So I have a 72 blazer with a summit universal wiring harness in it. I installed it new 5-6 years ago with no problems until now.
I just did a motor swap it has the same HEI dizzy as the last motor, Alt, etc. while letting it run to check antifreeze and purge the air out of the system it will died. It fires right back up, its not a fuel issue, definately power. When it dies my radio beeps (pioneer) just like it does when I turn the key off. I test drove it about a mile and it died twice while driving, but caught itself and fired right back up without me having to touch the key.
I have all power comming off the starter post, I have a 6ga straight to the battery, the one to the fuse block and the battery as well. All connections are tight and I have wiggled them while running and it wont die, also wiggled wires on the back of the ignition switch. It all started after the motor swap and I am stumped to what is causing this!
