You know, I had thought I remembered a stamped piece but figured I might just be old and not remember good. Wouldn’t mind a picture as I may have the thing laying around and if I knew what it looked like it might be easier to find.It’s a stamped piece I can take some pics. But a rod would work too
I think you're wrong. It's a solid round rod with stamped ends to make them flat. I've got an unmolested blazer sitting at home. I'll try to remember to get a pic for you.It’s a stamped piece I can take some pics. But a rod would work too
www.autometaldirect.com
Yes! No idea where that went.
ah, the fender extension. I didn't realize that is what we were talking about. I may actually have some I could sell. I need to look for them.
No worries, I’ll build one. Only looking to “appear” stock not actually be stock.ah, the fender extension. I didn't realize that is what we were talking about. I may actually have some I could sell. I need to look for them.
On the drivers side it helps protect the fuel linesI wonder if GM added that instead of the straight wire to keep debris from spraying on the back side of the body?
Ah, I see you may be right.On the drivers side it helps protect the fuel lines
