For some reason, I can't view the picture either, although obviously others can...
+1 on the restoration idea, at least that's my opinion - I get a huge kick out of the full-blown trail rigs I see here, and I definitely get lots of ideas from them, but at the same time it's good to have something set up factory original to use as a base line to compare against. You've obviously already read the Craig Artzner threads, so you know how much everyone has drooled over his '74 - - - it will take a bit longer, but the day is coming where we'll all be excited to see a super clean 76-80 half-top too. So I say, go for it!
But I'm not sure you really need to ditch the lift (unless you really don't like the stiffness). Original arch springs are tricky to track down, and they're fairly expensive. Also, keep in mind that if your lift has any age or miles on it, it may have sagged to the point where it isn't much higher than factory anyway (I can't see your photo, so I'm guessing here).
Plus there's the fact that back in the day they didn't all sit the same height right off the dealer's lot. I've got some old 35mm slides I should scan of some GM dealers lots in Montana I took back in 79-80 (I was in Jr. High, but foolishly thought I'd be marching down and buying a band spanking new one soon) that clearly show a wide range of stock ride heights. One of the reasons I took the pictures was to figure out why some looked better than others (ya know, so I could fill out the dealer option sheet right - man, was I dreaming!). I happen to prefer the slightly taller stance (2 to 2-1/2") as long as you run a 33" tire to fill the fender well, especially with the ralleye rims! I tell ya, that was THE look back then.
lochenjons had an excellent suggestion - sell off your 4.56's to someone building a trail rig, and swap in some factory 3.73's. I've run 33's on 3.73's for years, and you'll probably love them around town and on the highway - I've been pretty pleased with them on the trail as well, although I'm nowhere as near hardcore as most of the guys here.
Post more pictures so I can see too!
1978Blazerk5 said:
Well I have a question for you restoration guys.i am currently restoring my 78 blazer.for a stock look do you think i should unlift it?currently rancho 2 1/2 inch lift. and 33s. i dont wanna wheel the truck. i wanna keep the body in good shape.and this is the most origanal blazer i could find for the price.
