I though about that. Can they be drilled through and just a nut and bolt?I think I remember having that problem before and just tapping it for the next larger size. That worked for years, but for the last 5 years that tailgate has been on a shelf. If you wanted to be really cool, you could drill it for a steel insert. They're kind of crappy pot metal.
Anybody know if the 70's and 80's handles interchange?
I don't think that handle was ever changed. Neither was the outside roll down crank.I think I remember having that problem before and just tapping it for the next larger size. That worked for years, but for the last 5 years that tailgate has been on a shelf. If you wanted to be really cool, you could drill it for a steel insert. They're kind of crappy pot metal.
There is a roll pin that holds the handle into the crank. Double check the material around it is not cracked.The roll down crank for mine is loose. Is here a way to tighten it? I mean in the meantime before I swap the truck tailgate on the blazer
Yeah I'll snap a pic and update. The entire roll-up device on the tailgate is loose. I hold it still while I roll the window up or down.There is a roll pin that holds the handle into the crank. Double check the material around it is not cracked.
Yes... I'm actually heading to Orange County next week... where are you at?If you are still looking for a latch handle, I have one. Any trips planned to Cali?
22 / 405 merge - Valley View. I'll shoot you a PM with my number.Yes... I'm actually heading to Orange County next week... where are you at?
