This is off of my '91. Has been sitting in a garage for the last 2-3 years.
Has no rust whatsoever. Glass was put in new the day I bought the truck back in November of 2007.
The motor worked when I took the tailgate off a couple years ago. I started to take it apart to pull the glass but decided against it and let it sit.
I'm sure the guts could use some freshening up. The outside weather strip needs replaced.
A reproduction tailgate and glass from LMC will run $350 without any internals.
Asking $200.
Not opposed to shipping, but you would have to set it up as I don't have the means to do so where I'm located.
If you would want to pick it up, I might be willing to meet part way.
The bottom side:
Outside weather strip that would need replaced:
Asking $200.
The bottom side:
