blazer tank in k-10
4x4orbust
SE mass
hello all, i did some searching but couldn't find my answers...
I have an 82 k-10 that i would like to put a blazer tank in in lieu of the saddle tanks. what size blazer tank fits best? I have a line on a 35 gal, but wasnt sure if it was too big, or if the 25 gal just fit better.
also, what have you guys done for a filler neck location? i know i can't use the stock one, ideas?
thanks!!
same size sruare. just bigger capacity is deeper in hight.
so pick the size you want in the unit.
and the shortbed with 2 tanks would have been 15 gal x2 = 30 . so if me i would go the bigger size.
as much as i wish it was a massive beast of a k-5, it's the beginning of a massive beast of a k-10 instead....
how much deeper in height are we talking between the 2 tanks?
is therer a tech write-up on ck5 about this?
that helps a lot!! thanks for the link.
now, what about the fuel filler hose? not sure what to do with it, or where to put it. any ideas?
also, i have been searching for a write up on how to install a blazer fuel tank in a truck, but can't find it anywhere, is there something like that on here?
