Blazer's 85 Suburban "Twinkie"
Yesterday I roasted the tires in a smokey burnout for at least 100yds and the trans shifted into OD and I was still burning rubber. And I was in 4wd High with both axles locked.
So you did a 4x4 John Force style burn out? Weak.
Looks like some poured some black paint on the asphalt and smeared it.
Changed out the plugs today. They all had weird burn patterns on them. Have of the tip looked ok other half was a bit dark..
Put in a colder set going to see how it runs. They are alot colder so may have to step it up a level. Seems to run well for now.
