Bleed screw sizes?
dhcomp
1 ton status
Truckee, CA
Ok, so had to bleed the brakes on the burb.
WTF wrench size is needed on the front bleed screw? The 10mm was too big, 9mm, too small, 3/8 too small. Truthfully, i ended up using pliers to brake them lose. I hate doing that. I also used flare and normal style wrenches? What gives?
Same happened to me on the brake line fitting on the rear wheel cylinders? Is there a 9.5mm wrench i am missing or something?
Also, took my cheap a$$ flare wrenches back to kragen. Now i need a full set of small metric/standard flares. Do most people have the full wrenches, or crows foot sets? For most things, i HATE crowsfoot wrench deals....but for this purpose, they might not be so bad....?
EDIT: Crowsfoot deals are most expensive from craftsman. Guess i should get the full wrenches?
Suggestions?
Thanks guys!
Depends on the rebuilder, but should be either 3/8" or 10mm... if yours were inbetween, they may be beaten. I usually use a box end wrench, but ::shrug::
Carnac The Magnificent might foresee you replacing bleeder screws...
-- A
-- A
Agreed, i actually pounded a 3/8 deep wall onto one to break it lose :(
I just really didnt' want to go to the parts store a 5th time, and they weren't that messed up. Ill get one ones when i get ready to bleed again.
The fitting that really pissed me off was the brake LINE fitting on the rear, as i have no idea how i'd replace that without redoing a good part of the rear line :(
So....someone has to know. What size were these supposed to be on a 10bolt front?
