Bleeder
Snowman1000
Freeland Michigan
Alright I went under my truck today to bleed my brake lines and got to the rears and my bleeder snapped off what do I do now. The truck cant go anywere what do I have to fix??? this is the rear axel 12 bolt Drum Brakes
get an easy-out and remove broken bleeder and get a new bleeder from parts store and thread in
If you cannot get the old bleeder out using the abouve method, either bleed it by cracking brake line or just go buy new wheel cylinders (they are cheap).
Alright I know that an easy out is fairly self explanatory but I have never used one before so please explain the process and what size easy out should I get???
take one that barely fits the hole and tap it into the broken bleeder then just turn it out like your lossening the bleeder
Alright now I am upset I tried to use an easy out and bent the easyout after using penetrating oil on it for 2 days so I was going to try and change the wheel cylinders started taking things apart and relalized I dont know what the hell I am doing so I am going to need some help here I have had enough and am going to just replace the dam* wheel cylinders. to take off the wheel cylinders do I just take the two bolts and brake line off the back of the drum. I am so flippin upset please help. Also on a lighter note for the senior poll I got the Biggest Clunker Award coincedence I think not.
Well I got the wheel cylinders off now I need to replace those and when I was taking off the brake line it broke twisted clean off now I need to see how the brakes go back together (spring locations I had to take a few off to get the cylinder out).
This is the best I could come up with.
