Bleeding brakes with abs 2000 2500 truck
brans87
- In Memoriam -
North Carolina
Can you bleed the brakes on a 2000 2500 truck with abs or is this job needed the factory scan tool to work abs to bleed correctly? Family member replaced line on right front hard line due to rust and had to replace caliper due to them messing bleed screw up and it not coming out now. Need to bleed ASAP. Thanks guys
