Blew the alternater on the turd exploder
70jimmy
3/4 ton status
Staff member
Moderator
Released from Pueblo, told I belong in Southpark
Well picked up the kid from school today and saw the battery light came on. Looked at the voltmeter and it was down around 9 or so. HMMMMM
Took it home and thought well maybe cables need cleaned and not getting good contact. So I parked it and later went to move it into the garage and when I fired it up the alternator started makeing bad sounds. Clue #1
So take the old alt off and have wifey grab a new one on way home from work. No problem. 15 minutes and its in. Fire it up and no change. OK
In the paperwork for the new alternator it said I should change the voltage regulator at the same time. Well never heard of that before but OK. :dunno:
So start to take the voltage regulator off and notice wires from the regulator lead to the under the hood fuse panel. :thinking:
So I open the fuse panel and there is a fuse labeled Alt. :thinking: Yep its bad. Find fuse in garage and voila'. Alternator was bad anyway but I was going to run down to the parts store and get a new voltage regulator for $25.00. I would have gotten home and still no worky.
FYI its a 1991 Ford Explorer XLT 4.0
