blew up another ujoint....help!!
Hey justin, theres a place down in dallas of CF hawn that will have exactly what you need used. I'll see if I can find their number for you.
If your yoke is jacked up, then you need to replace it. Plain and simple. Don't keep using the same old yoke. Repalcing/rebuilding the shaft won't do any good if the good ears on the joint that blew up were in the shaft...You need to replace that t-case yoke. You should prolly lower the t-case a bit too. The tapered blocks help your pinion angle, but do nothing for the angle at the t-case.
I agree. Your yokes, and even the drive shaft u-joint ears may be all twisted and beat up. If this is the case, then your u-joints are not seating in there saddles properly, and twisting the u-joints all out of shape as they start to move around inside of the yokes, and drive shaft ears, when you drive down the road.
I would bring it by but all i have is the front shaft. I need to get a rear yoke for my 203, Kirven said you may still have one.
I've still got to pick it up from him. I will swing by his house tonight and get it. I will give you the yoke from it in trade for yours. Cool?
