Block Castings
6.2puller
New England
I have an engine here that was removed from a 79 K5 Blazer and the VIN denotes a 305 V8 2bl carb.
The casting number on the back drivers side of the block is 3970010
Wich by my research means
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
So if the motor were a 79 it would be a 350 but we know by the VIN it is not original.
Any ideas on how to determin this other than pull the oil pan? It is still a complete engine with TH350 so I can't stick it on the stand yet to pull the pan.
ive noticed on 350's on the back where you got the number, the blocks that ive seen say GM 5.7L
The number of "0010" 350's vastly outweighs the number of 327s, and it's guaranteed you don't have a 302 on your hands. Theres also the matter of 2 bolt vs 4 bolt, you can't tell that one externally, drop the pan, or get a scope, drain the oil, and perform surgery through the oil plug.
the 5.7 or 5.0 is only on the efi blocks as i have seen. if you have the tranny off and fly wheel or flex plate off you can look at the crank flange and match it up to a pic in some of the books and that will tell you what you have as far as 305/350 so on.
