cabledawg
Secret Squirrel
As the title says, who is running block heaters and which style do you have? I've seen the magnetic ones on the pan, the block elements that go in place of the freeze plug, the sticky mat that goes ont he block or the pan, or the ones that go inline to the radiator hose and circulate the coolant.
Now I've used the magnetic ones, but on a tractor so it was easy to place or remove it. I've also used the freeze plug one that was on an old Ford I had years ago. That worked well, but I'm not real keen on pulling freeze plugs. I've also seen the inline coolant version, but again for a tractor, and while it was very efficiant(sp?), we would periodically have to replace them because the pump part would fail. Cheap and easy to replace, but aggrevating when they dont work.
So give me your thoughts, theories, or experiences on block heaters.
