Block ID numbers??
jeff in co
Colorado Springs
Friend just got to take his father's Corvette, and it appears to be a numbers matching.
On the block, are some numbers as well. Can anyone interpret what they all mean??
Thanks!
V0415CLA
Small block ?..
According to the site I used on google to look up "CLA" ,it could be one of three different 350's listed for Vettes..
1973 350,190 HP, TH400
1974 350,195 HP,TH400
1977 350,180 HP, Automatic trans..
block casting driver side rear abouve bell housing flange . this helps id th block size best . then with engine out you can id the crank shaft via the flange shape were the flywheel / flexplate bolts up and thicn of thick parting line for cast or forged crank .
350/180hp/auto
Engine assembly date April 15 @ Flint engine plant, the blue paint is the correct color for that engine.
Match the Vin # to the engine pad for the original engine.
That engine info all matches then.
The engine VIN matches the VIN on the A pillar.
The trim tag is I26 .... April 26th 1977. So the engine was assembled a couple weeks ahead of when the car was trimmed out.
