Does anyone know the reason for the blocked water ports on the rear of the intake manifold?
Gus
Gus
The intake manifold doesnt have provisions for water passages probably to keep the deck low for the distributor. First time I took the 350 apart I thought that was strange after just rebuilding a ford 390FE that has huge water passages all around. I suppose it isnt needed though as the cold water is pumped into the water block and pushed up into the heads and out towards the front. It would be a good idea to pick and scrape off all the scale that builds up in there if you have the heads apart.
The heater supply/bypass outlet is on the front of the engine near the thermostat and that passage should never be blocked. I've recently rebuilt the 350 in my truck and swapped between two edelbrock aluminum intake manifolds, both had no rear water passages built into them. However, the water passages on the intake gaskets were open on both the front and rear so it wouldnt matter what side they were put on.
I dont have much experience with chevy SBC's but both of my aluminum intake manfolds had no rear water passages at all, only in the front where the thermostat and other outlets are. If your intake manifold has water passages on the front and rear, then I dont see why it should be blocked the gasket. I have seen people block the EGR ports that way but never a water port.
