Green Monster
Anyone ever heard of a power steering pump barfing out a bunch of fluid when it's hot? Complete new system (hoses, pump, box). I was driving around during the heat wave to get the bumper installed and a smog check. Probably 105 out. Hottest the engine's ever been since I've owned it. All of the sudden, I look back and there's a huge plume of smoke following me. I pull into a parking lot, and there's fluid dripping down out of the pump. Let it sit for maybe 15 mins, restart it and no leaks. Drive home, pump is making a little noise, little tougher to steer but I still had power assist. Check the level of the ps pump and its dry on the dipstick. Get back to it after a few days, and fill it up (overfilled, but I figured some of it would circulate through). No leaks when I start it, but once it got warm and I revved it up, started leaking again. I can't tell where it's leaking from, but figure if it's the lines, or a crack, it would be leaking all of the time. Think I overfilled it and it's puking fluid? I'm just surprised it would barf a ton of fluid out all at once. Thanks for any direction.
