Blow-up picture or step by step for 14bff
XHitman396
Broken Arrow, Oklahoma
anybody gotta blown up picture of a 14bff, or at least one drum. I finally got one and realized i wasnt sure how to get to the brakes. i got the axle off and figured i better wait to go on. if not, can you do a step-by-step of how everything comes off?? thanks guys..
if press-on drums.
after it's jacked up and the wheel off.
removed axle shaft
then remove spindle nuts
pull off drum/bearing hub
there are the brakes.
Usually there is a locking ring in there with tabs on it that are bent into the notches on the spindle nut. You can use a screwdriver to bend them out of the way... then go at it with the 6 prong socket.
