Yes, I'm sure.
The trouble is, the parts books at various parts stores for this part, including AC Delco, is flat out wrong. I know. I researched this very item. If you look in the GM parts books, there are different numbers for the blower wheels. The no-ac, HD heat one is separate, same height as std heat, but slightly larger diameter. The HD heat also takes the same motor as AC equiped trucks, if you look carfully, which, as you mention, also has the little cooling tube to help keep the motor cool. When I ordered various GM part numbers from anyplace I could find the real GM parts, they all came, and you can then see the differences. There are three wheels (actually 6). STD heat, HD heat, and AC with or without HD heat. The reason for 6 is somewhere in the mid-80's GM changed to press-on wheels & motors, as opposed to bolt on. The aftermarket wheels come with an allen set screw which will adapt to both.
BTW, if you order the aftermarket std heat no-ac wheel, it's slightly less tall than the OEM version, as if the blower and wheel already couldn't keep the windshield defogged on a rainy day, do youself a favor, and find a wheel from a junkyard if you need one.
I looked up and ordered (found a dealer out west that had it stock) the metal case that goes on the outside of the firewall for the no-ac HD heat version. The case will accept a larger diamter wheel. Mabey it was only the pre'80's version, there were some differences there as well.
The switch in the dash is also different for HD heat, as you mention. The off control on the upper slide is only on I think it was post-80's models without the 'pass thru ventilation'. If your wondering what that is, if you have it, you've probably also wondered why there is a torrent of air on the floor when all the vents and everything is off, that is because the pre-80's heat boxes on the inside of the truck firewall have a giant gaping hole in them, they called is 'pass thru-ventilation' and was a feature until too many people bitched about it in the late 70's to remove the 'feature'. pass-thru vent vehicles have no off switch on thier fan or upper slide switch.
