It is not uncommon for old wiring harnesses to have that issue--for some strange reason a wire will often "dissolve" in one spot somewhere,without leaving much evidence,and it sucks trying to track down that spot and repair it..
I usually just splice a new wire in and leave the bad one in the harness,and snip both ends off flush with the outer conduit..after spending a day finding out which wire went sour!..
My friend has done a lot of vehicles with wiring issues no other shops could "cure" or had the patience to track down..it is tough giving a customer a estimate,when it might take the better part of a day or longer to find bad wires,then fix it in 5 minutes with a piece of new wire and a buck's worth of solderless connectors and tape..he doesn't like taking those jobs on because they waste a lot of time,when he could be doing brakes,exhaust,or other much more profitable and easier jobs..
