Wrench
Why does this always happen . . .
1982 CC in sig.
Decided to do an IP swap two days before a scheduled trip to BC, went fairly smoothly but,
Key in run, engine off, everything looks fine.
Key in run, engine running, the fusible link off the distribution block on the firewall starts to smoke heavily within 30 seconds, and fries. Have been swapping in pieces of small-gauge wire while experimenting so I don't blow the rest of the harness.
All I did was swap the IP to a 4911 and relocate the lift pump to the frame rail by the pass. fuel tank instead of on the inner fender. Already experimented with disconnecting the lift pump.
Ideas? I'm supposed to leave tomorrow at noon . . . .
1982 CC in sig.
