Multi meter-Test alt output to battery while idle, then rev it up and watch it. Could be the internal regulator
Not exactly sure what you are saying. Is there a separate fuse going to the power block that is blowing? If that's the case disconnect everything going to the power block then touch each thing 1 by 1 till it blows that way you will know which wire is causing the short. wiring is a slow tedious job so you just have to play the elimination game either manually or with a multi meter.
PS the porn is good but a pick of the wiring block, alt and battery might help out a bit more
Ok, I just got back in town with decent internet, and am able to post. After thinking about this a bit, I did not have the problem until I replaced both battery cables. My battery has both posts, so opted for the side post cables.
You will notice the questionable fuse in this pic and a distribution block that it goes to.
From the distribution block you see a red wire going across the core support, and another wire with the mini glass fuse Diesel4me mentioned (it was good)
from there it goes to the below block (this was supposed to be temporary but like most things fell by the wayside) you will see that two wires leave and go to the alternator, and a third goes to a mess of wires near the DS headlight.
Here they are going into the alt.
and down into the headlight fiasco, where low and behold the other mini fuse was blown. I replaced it but it mad no difference, though some time ago I found the PS mini fuse blown and the truck would not start I find that a bit curious.
I will also add that when I first put the 30a fuse in, it lasted over the course of 4-5 startups. But now it does not matter 30a on down blow as soon as the truck is running 1-2 seconds max. You can tell when it blows, the interior light brightens, then goes back to normal. No issues while its running everything works (well every thing that normally does
). There is just no power for a start.
SPD I also, pulled every fuse and wire from the fuse box, except the main feed coming in to power the ignition, it still blew right away, one other thing that I noticed is that after the fuse blows, the tach needle fluctuates erratically. So I guess after a few days checking, and just dealing with it so that the kids and I could enjoy some time away we still have an issue.
Any ideas, I am hoping the masses can help, we need some action in the first gen forum.
