Had a bad weekend guys. Got a sick small block Chevy in the garage right now. Driving my 70 Blazer on Saturday and think I just experienced my first blown head gasket. Was driving it with a heavy foot and... bam. Engine started running bad and smoke out the exhaust. Pulled over and collected my thoughts. Tried to start the engine to limp it home, and it cranked for a few turns then hydro locked. Towed it home and pulled spark plugs. Milk coming out of #7 cylinder. Drained the oil. A ton of coolant came out with the oil. Sprayed the cylinders down with Sea Foam and spun the engine for a second or two. A guy at work told me to drain the radiator and change the oil, then run for a minute or two to burn off the excess coolant in the engine. Then he said to pull the engine and check for bent rod or cracked block. Do I need to do this? Would the starter have enough torque to bend the rod on it's own? Can I replace the drivers bank head gasket and see what happens? Any recommendations? Engine is 383 stroker/ .60 over/ iron vortec heads/ 9.5 compression ratio. Thanks!
