blown heater core....help..
gabdam
NEW YORK
i drove my 86 jimmy today and smelled the sweet smell of anti-freeze, so i pulled over popped the hood everything was ok there but notice anti -freeze leaking out by my passenger door. i guess its safe to say my heater core is shot. the carpet is all wet and nasty. has anyone ever changed there own heater core and how difficult is it to do? i have'nt really taken a lok at it because it was dark. any help would be appreciated....how much does a new heater core cost?.................THANKS
It aint too hard.I pull my inner fender well to get better access to the bolts for the air box but I dont know if you have to. To me that was the worst part.But who cares about heat, just bypass it. Worry about it when it starts gettin cold :)
All work and no beer makes Frizz a dull boy<P ID="edit"><FONT SIZE=-1>Edited by FRIZZLEFRY on 05/19/01 08:16 AM (server time).</FONT></P>
One of the boys wrote a pretty detailed article on changing out your heater core. Check out the CK5 "technical" page- hit the trail map above and click on technical...............
<font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
I changed the heater core on my 89 last summer It was pretty easy.It only took a couple of hours. I think it is similar to yours.
1.Drain raidator&Disconnect heater hoses.
2.Take off the heater case to firewall screws and nuts from the engine side of the firewall you also may have to take off your radio antenna if you have one.
3. Remove glove box to gine a little more room.
4.depending on how much room you have you may have to remove the ECM and right side kick pannel.
5. Pull out the entire heater case. If there is not enough room take out the nut and bolt on the lower right side of the dash and lift up the dash a little.
6. remove all the little screws and split the case apart. take out old heater core and replace.
When I tried to replace my heater core in my 85, I found several little problems. First, the door that controls the air was in bad shape. The little clip on it was broke so the door wouldn't close. After I saw that, I went and got a junkyard box that had a good heater core. My question is, how do you split it apart? I couldn't get to the core on my new box. I took out all the little screws but it was still held by 'something'. I am thinking it was a rod for one of the doors. ANyone else have this problem?
GSB
Forever #3!!
so the best way to get it out is from the outside of the truck not from behind the dash..how long should it take me?
The bolts that hold the heater box in are under the hood. The Heater box is in the truck behind the glovebox.
Here are instructions. http://grimsk5s.coloradok5.com/<P ID="edit"><FONT SIZE=-1>Edited by Grim-Reaper on 05/19/01 04:34 PM (server time).</FONT></P>
Grim,
Nice write-up. Perfect timing ... started smelling that stuff last week ... and didn't know about this!
LMAO about all the stuuf you found in there!
Thanks
To take apart the air-box itself becomes a chore if you miss the screws that are attached from the inside. Look closely at the foam ring around the backside of the box and you will find two or three holes that you can get a small socket or nut driver in to take out the bolts. They are very hidden, and will make you start looking for the BFH in desperation.
Derf00
http://www.derf00.coloradok5.com
"Four wheel drive allows you to get stuck in a more inaccessible place."
