Wanted Blue seatbelts
Blue85
Yooper
Keweenaw
Looking for stock blue front seatbelts, both the floor mounted "receivers" and the wall-mounted belts. What I have is still functioning, but the nylon is showing wear and some of the plastic bits are broken.
If you have no luck here, check out car-part.com. I saw many blue belts when looking for rare black ones. Most salvage yards will ship.
They are used but are in decent shape. A tiny bit of fray in one spot you can see but not bad. I think they could be cleaned up. Is this the right blue?
Ive got a clean used drivers side. Rt side was gone. I bought a set off of LMC. They work well. $160.00 for the set.. You can have the one I have for shipping cost.
I can't remember how the rear center belt connects to the seat. One of those might work well for my center front seat. It has a generic gray one one there now.
I've got a local wrecking yard with lots of 84 - 88 seatbelts and probably even more in the older years. What years are you guys looking for?
My brother in law says $50 bucks for the ones in his blue 1990 suburban.
Did you see these yet? Might get you half-way there on the passenger side.
https://ck5.com/forums/threads/new-73-87-blue-lap-seat-belts-lmc-part-38-2240-ll.334038/
Wanting to stay with 3-point, not convert to lap belt only
I think I have a nice set that I just pulled out of my Jimmy project. Will try and get pictures soon!
May be interested in the whole passenger side or just the wall box and floor-mount section, plus the slider cover(s).
Suburban belts are different than K5.
