TucsonK5
Confirm my fears...
The problem: recently rebuilt Toyota 22RE smokes on startup and won't stop smoking until running (idling) for ~15-20 minutes. Blue smoke, no water in oil or vice versa. I am thinking it is the rings because bad valve guides wouldn't cause this duration of smoking and I can't think of anything else that would do it. Agree or disagree?
Background (sorry it's so long but I want to provide all details):
So, recently I rebuilt a Toyota 22RE that I bought on Craigslist for $100 (long block). The guy said it had ~115K miles, smoked on startup (I think valve stem seals at the time) and he decided to just buy a long-block stroker motor instead of working on it.
Pulled it apart, everything looks good, main and rod bearing journals are well within stock specs (miked), neither block nor head is warped, cross-hatch pattern still visible in cylinders. I did not mike the cylinders because I saw the cross hatch, don't have an inside mike, and the reported mileage was so low for a Toyota engine. Rings looked good, no carbon build-up, and rotated easily. I didn't hone the cylinders and used the original rings. All seals and bearings replaced. Runs well except for the smoke. I haven't really gotten to get it up to speed on the street because it is not registered or insured.
Cold/dry compression was below spec (all about 125-135 PSI, minimum is 142, standard is 178 PSI), cold/wet added about 10 PSI to each cylinder. I haven't done a warm compression test yet because I smoke out my neighborhood and have people showing up to see if everything is OK.
Thanks for the help.
, different rod for #3. Started it up last night, smoked for about 1-2 minutes and no more. This motor is finally done and I am sick of it.
