Clod_King
How aggressive can a boatsiding get??
I want to do a fairly aggressive boatside soon. But I have a few questions I need to get answered...
Like if I start at the chassis, and work out, how steep of angle can I go before the pedals get in the way???
Plus I read somewhere on here that burbs have crappy frames, so should i box the frame before going through with this??
My plan was to weld in some 3/16, or 1/4" 2x3 tubing where the body mount points are, and then weld a radiused tubes to it for the boat side. I wanted the bring the boatside up the main body line on my sub. Then inbetween the tubing I'd screw some 3/16 or 1/4" aluminum to fill in spaces (to keep the weight down a little bit....
I wanted to ditch the rubber body mounts, and just mount the body through square (well rectangular really) tubing so it would up the rigidity of the frame.
Also, I wanted to incorporate a roll cage into the boatside.
Bad idea?? or good idea?? Gimme your ideas, and thoughts, and flaming if need be....
