Boatsiding up to the door hinges
gotmud77
bellefonte
I have searched and found different post but not really any pics to speak of. I found some that used the factory doors but none that moved the door sill up to the bottom of the factory hinges. Any pics would be great. Inside,outside what ever is available.
Thanks,
x2 any posts haven't showed clear pics. the only threads i found were supersize's and russ's but not much info!
There was also a user by the name wiesel? It looks like he isnot a member anymore. Maybe somebody has some pics of his k5.
weisels got pics up in webshots . http://community.webshots.com/user/weisel_77
Hes a good guy , shows up to wheel when he can .
Look at the last pic in his fab folder , he moved the lower hinge up after he cut it off .
I got to go take some pics , was cutting on mine an hour ago . Not going too high , just to the bottom of the lower hinge . Damn wifey gets her way , she wants half doors for her days out LOL
Eli (wiesel) has his up to the middle of the lower hinge and made his doors fit. I cut mine up to the same spot and made my doors fit too. I don't have anypics of my doors though.
That's funny, I've been researching this very thing and just recently PM'd this guy asking for some close-up shots, though this isn't technically boatsiding.
Not technically boatsided, but the same basic idea. Keep in mind that if you want to truly raise the rockers up far enough to require boatsiding than you will have to modify the lower door hinge (assuming you are keeping doors) and will then start having issues with keep the window mechanism functioning.
I cut out the stock rockers and lower sheetmetal along the front and rear fenders up to the bottom of the stock lower hinge, and then grafted in 3x3 tubing. For perspective of how much higher the new rocker is, there is almost 5" cut out of the bottom of the doors. I also replaced the floors with flat 1/8" plate at the same time, and with the floor basically at the same height as stock there is about 1/2" lip where it meets the new 3x3 rocker sits higher.
- 6.2Blazer
Yep, that's my red and black POS. I'll try to get a few close-up pictures of what I did with the rockers.
As mentioned in my previous post, if you go up any higher you will have to start modifying the lower door hinge and then you will start having an issue with being able to lower the window all of the way. Originally the doors had power windows and the bottom corner of the window motor/regulator was just starting to hang out the bottom, but I had plans to convert to manual which gives a little more room.
There is around 5" cut off the bottom of the doors for reference.
I chose to go this route because I wanted the rockers raised, and I wanted to be able to use the 3x3 tubing as a slider to help protect the sides of the body. On a lot of rocker/slider installs if you keep the tubing in far enough that the complete door still closes then the tube does not stick out far enough to protect the sides, you would probably have at least 3" of fragile body panels that stuck out further than the slider.
gotmud77 said:
...but none that moved the door sill up to the bottom of the factory hinges.
Most of the Zonies around here run high skids so that doors are no longer an option... Some examples:
Marv
marv_springer said:
Most of the Zonies around here run high skids so that doors are no longer an option Marv
hey marv i notice the boatside pics are not plated. wouldn't a smooth plate be less likely to hang up on rocks than the attachment tubes exposed?
Yep... In fact most of these trucks still have big "sight holes" in the floor...:haha:
A smooth plate across the bottom would be a good idea... but usually, you just slide along the outer edge of the [==] tube... or the frame and crossmember hangs you before those tubes do...
Marv
