I did mine similar to Brian's (bp71k5) I took off all the nuts on one side and left the bolts in and loosened all the nuts on the opposite side but left them on the bolts. I took a long piece of 2x4 and or 2x6, what ever fit under the body, and use my floor jack to lift the body up near the mounts. I had to use some blocking between the jack cup and the 2x material because of the distance. When I jacked up the body just in front of the the rear axle near the rear spring front hanger I was able to get 3 of the body mounts with one jacking. Then I jacked up the body under where the drivers seat is and got 2 of the others and, well, I forgot where I jacked the body to get the radiator core support mounts installed.
