can anyone tell me if the door latch strike pins are supposed to have the little nylon plastic piece on them from the factory. Having touble getting the door the close easily.
Also where can you get the little body push in clip thing a bobs that help hold the emblem on the passenger rear fender, also the little rubber gasket is pretty wore our
the last little piece I am looking for is the little plastic insert that you screw the adjustment screw in for the front lower light bulb to make the alignment adjustment. My plastic piece is broken and the light is all tilted in the bezel...
thanks in advance
thanks in advance
