When I got the truck I put on a 1” ORD body lift and new bushings along with a 4” ORD custom leaf spring lift and 37’s. The aggravating part is I have to air the tires down to about 5psi to pull it in and out of the garage and doing some quick measuring I’m about an inch and a half short of fitting in at full pressure. Makes it a chore when you want to just hop in and make a beer run.
So I’m debating yanking the body lift off. I put it on because I like the room it gave me to get to things high up on the drive train (top of the gas tank for example) and give me some more fender clearance. Truthfully, I could take it or leave it. I’ll trim the fenders some more if I need to. What are y’all’s thoughts on body lifts? Useful or just meh?
