Body moldings for rear corners (1989-91)
RJB44
Northern Virginia
Does anyone know a source for new corner body moldings for the rear. This are made to wrap and are a little thicker then the side moldings. Thanks !
I believe I've seen them in the LMC catalog but I'm not too sure on the quality of them though. Another place to look for them is your local auto body supplier. Depending on how good they are, they can order trim pieces and moulding that are either NOS or as close to it as posible.
Those are a specially shaped piece - not just side molding curved into an arc. They sit on top of the bodyline down there, so the side against the tailgate is molded to cover up the gap.
I think the kit that LMC truck sells works with the molding now.
Check out page 35 of their catalog. Items 10 and 11 are clips the bend the molding around the corner and hug it to the truck at the same time. Eliminating the need for the special custom pieces that came from factory.
I to will have to replace my entire molding on my truck in the next year or so when I fully strip my truck for new paint and repair. So I'll be getting this kit unless someone finds a better one.
