Body mount bolt holes not lining up
centexk5
3/4 ton status
Georgetown, TX
I’m taking the body lift off of my truck and the bolt holes aren’t lining back up. I’m doing it one pick at a time and I’ve gotten 2 of the 6 lined up. Guessing the only easy way is to jack the body up on both sides and slowly push and pull it around until everything lines up?
yup, loosen them all.. than jack up the ds or ps of the rig and remove that side... replace/jockey.. get bolts started.. repeat on other... tighten all...
Then something is bent,and when you release tension it all moved.
Sometimes a ratcheting tie down strap can persuade things to line up better
No. Was working my way down one at a time.
In another note, I seem to have lost one of the mounts so I had to order a new kit this evening.
