body mount bushings install ?
gangbox1
Registered Member
HIGH DESERT NM
hello. im putting in poly bushings on my 72 cst. ive got off all the bolts going thru the frame. im also putting on a 1" ord body lift. whats the best way to put it all on? do i jack up one side at a time? or the back , then the front? advice appreciated:bow:
I jacked up the body with a 2' (+/-) piece of wood supporting the body. Like a drywall tee. Did it at each body mount, replaced the mount and moved to the next. After they were all in place, installed nuts. I guess you could jack up an entire side at one time, but it seemed easier to do one at a time.
