CGT80
I searched ck5 and the net but didn't find a lot, maybe someone has some links.
I have a 79 chevy c20 pickup that needs the cab and core support bushings replaced. I bought energy suspension 3-4103 a few years ago. Today I tried to loosen the bolts for the mounts.
Passenger side front of cab- the bolt starts to loosen, but the captive nut twists back and forth also. My impact will not work with the loose nut but i could turn it with a big ratchet. Will I need to cut the floor and reweld the nut, or is it possible to replace the mount the way it is? Does anyone have pics of the top side of the nut with the floor cut away?
core support-one nut will come loose, the other just spins the bolt. I have not been able to see the top of the bolt yet, but I can feel it spin. Does the top have a head for a wrench or am I looking at some more fun for this one?
The rear bolts at the cab start to come loose, but I am afraid of what might happen as I remove them. How is the nut secured? Is it possible to have to cut the floor for those also?
I sprayed all the bolts with penetrating oil today. I have been putting this off because I have read that it can be a chore, but now I am missing big chunks of the old mounts and need to get it done.
I also bought the rear spring bushings. I have a 14b ff with 9 leaves in each pack. How big of a job is it to do these? Any links? I'll do a search for this one right now.
Unfortunately this is my daily driver/work truck, and my k5 is down, so I can't have it undrivable for more than a day or two at a time.
Thanks guys
Thanks guys
