Body Mount Removal Question
ARAMP1
Aviator Extraordinaire
Memphis, TN
I think I know the answer to this, but I'm replacing the body mounts and they all came out with no problems except for the pass side rear. It just spins. Any recommendations on how to get it out?
If it spins then the nuts broken loose. It's time to holesaw the spot above it so you can put a socket on it. :crazy:
It actually wasn't that hard. I just drilled a 1.5 inch hole right above it and was able to stop the nut from spinning. Went to ACE hardware and bought a plastic plug, put some new dynamat over it and it's done-ski.
It's guys like you that I hate. I'd have had to cut a 4x4 hole to get a pair of vice grips in there and keep it from moving only to cut my hands 3 times and have to fire up the torch to finally get it out. :haha:
I have very bad luck with stuff :doah:
