Body Mounts
pomai
Oahu, Hawaii
I changed the radiator core mounts, now I'm changing the body mounts. any advice on how to go about this is greatly appreceiated.
Do I start with one side and then the other or do I start with the front and then the back?
Were from underneith the Blazer do I lift from?
Thanks,
Ed
When I replaced mine i did one side at a time. Just losen up one side a bit than remove the bolts from the other side. Raise the body just enough to get the old ones out and new ones in.
you just need to get the weight off of them. I did one at a time and then went around and checked the tightness twice.
