Body Mounts
pomai
Oahu, Hawaii
I installed LMC rubber body mounts, from the radiator core all the way to the rear. the gap between the fender and the doors are uneven.
How tight are the radiator core suppoirt rubber mount bolts supposed to be?
Thank you,
Ed
Thank you,
Ed
If they were good before the new mounts and now they are off, you might have the wrong parts in the wrong plce.
Or someone did some realignment of the body panels using fender washers when the mounts were shot, and now you have to do it again.
Most pieces are adjustable with some fender washers.
Is the gap different from side to side or on the same side top to bottom?
