I just picked up a 91 blazer with a good body and I'm going to swap the body with my 85 Jimmy body. When I do that can I legally take the vin plate off the 85 and put it on the 91 body, or do I register it as a 91 even though it's on an 85 chassis?
, I imagine the specifics will vary state by state, but IIRC in my state you would be required to use the newer body and then be required to meet any requirements for the year vehicle (emissions, saftey etc.) Just fyi, the frame has the vin on top of the rail under the pass front floor pan, without a body lift it would be pretty hard to see/read. The number stamped on the vertical side of the rail is a part number.
I dont know what the law says in your state, but in NC the vehicle is registered as the frame and the body doesnt matter. When I satarted looking for a body to use for a swap I found one at a junkyard with no title and called the DMV to ask how I would need to go about titling it and the woman said you title the frame and put whatever body you want on it. So when I get done my Blazer will be titled as a 76 but will have an 88 body.
