slimlynn1 : [you need more power.]
I know. I ggot a little over 198,000 on the original 350 it will get a 454 at the end of the summer
johnc : [You might want to try stalling your converter out when you launch, stand on the brakes and rev it up in gear until just before the wheels start to spin and of course more power wouldn't hurt either ]
I thought about that but in 1rst and low everytime I touched the gas the whole truck tweeked and I didnt want to push my self over the line (my rear seem to hold a little better than my front) because then I would be disqualified
84 chevy k10 : [If your engine is bogging in low gear, it's probably not running right. I'd bet your timing is slow or you have a vacuum leak or something.]
That is what I originally thought too but after my first two runs we checked everything and she was running great. My timing was actually advanced so I am not sure.
Hustler : [I have a question, are you sure you were bogging down or just spinning the tires? Do you have a tack that you could look at to see if you are in fact spinning the tires before hooking up in the mud or in fact bogging down? If you are bogging down, then you can either try to tune up your engine to try to get more power out of it, or air up your tires more then normal. by airing up your tires, it will make it loose some grip and might get you out of the hole without bogging]
I am sure I was bogging. mtblazer 89 has the same problem sometimes. My tires were at 33 psi and I was bogging off the line when floored no where else. I cant really tune up the engine anymore without a cam or heads. It is getting headers here shortly and I am going to put a 454 tb plenum on it to see if that will liven it up. Once again 198,00 it is kinda pass the tune up stage, but it has all new ignition components (msd), new plugs and wires, rebuilt tb with all new sensors (in the last 2 months).
mtblazer89 : [It was bogging the enigine just wound up slow until it hit about 1500-1800 RPM's then you could hear it start going]
Exactly. I need to build that 454
sr175 : [check timing, you have a little gear mismatch there and more power . Could try a cam thats better for that rpm range or the many other upgrades you could do.]
Timing was good but I am going to look into the cam.
rjfguitar ; [Just something small but NEVER use OD offroad where there is a big load on the tranny. OD is for puting down the highway at 55mph+.
I would just say your motor is tired and lean on power. My old 350 did the same kind of stuff when it was still in.]
I know I drove it from home got there and did my practice run right away. So forgot to run it 1rst or 2nd. Learned that lesson real quick.
Thanks for the help anymore ideas. /forums/images/graemlins/k5.gif
