Bolt in steering box frame brace
boz42
Hopewell, Tn 38058
I need to put a bolt on steering box brace on my '91 CC. It has the factory oil cooler on it. The lines for cooler run through a hole in the crossmember where the bolt in brace wound go. Looking at my trail rig which has the bolt in brace already, it looks like I will have to move the cooler lines. I know one of you has already done this. Will I have to re-route the cooler lines? or will the brace clear the lines? Thanks guys.
I had no problem with mine. No body lift. Just moved them a touch. Been running for over 4 years no probs.
brace
Just installed mine this past weeked. I just had to adjust the slack a little. Just put it on, no problemo...
